メインコンテンツにスキップ
Samsungの第五世代Android携帯のGalaxyスマートフォンは2014年4月11日に発売されました。指紋認識、より高度化したカメラ、より拡大したディスプレイ、防水性などを含む改良されたセルラーフォンです。4つのカラーから選べます:黒、ブルー、白、コッパー
577回答 すべてを表示
締切られた回答
How do I access the letters instead of numbers on the dialup pad
can`t find anything on the dialup pad to change numbers to letters
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 15
14 件のコメント
That's the way it will look. For instance, when someone's phone number is 1-800-CALL-NOW, their number is actually 1-800-222-2-555-555-66-666-9. That's how it looks. The letters are just so you can spell things in a phone number, but it's still just a number. To the dialer letters are just numbers.
さんによる
No answer …same question..how the !&&* do I access the letters and symbols on my Samsung Galaxy 7 phone key pad?
さんによる
I won't my old letter back I can read it
さんによる
How can I do this for a password with some numbers and some letters. It does not know what I am saying because it is not a word..
さんによる
I have this problem, Human resources in my country lets me speak the first 2 passcodes they need to let me talk to someone then I'm asked to input a third which ends in a letter, (this is new) there is no way I have found to input anything but numerals, we are not talking about the corresponding letters assigned to each numeral on the keypad so we can work out what "1-800-CALL-NOW" is but to actually input a letter.
さんによる
9件以上のコメントを表示
コメントを追加
5件の回答
最も参考になった回答
That is what you dialer should look like. To use the letters under the numbers, enter the number to the count of the letter you want to use. For instance, if I wanted to enter the letter B, I press two twice. If I wanted to enter O, I press 6 three times. Understand?
Hope this helps!
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
thanks for your advice George. I pressed 2 twice, but all that came up was
2 twos. same with o, up came 3 sixes. What do you think?
さんによる
Sounds like tom wants his password to be a word instead of a number. Like using the letters on a standard dial up phone to spell it out. For example WORD would be 9673
さんによる
The answer given by George A. is totally wrong. The answer given by mayer is the correct answer.
さんによる
Some carriers require a letter in the passcode to unlock the phone. I was FORCED to use a letter and now my phone is bricked because I can't type a letter after a system update.
さんによる
コメントを追加
Its not helping cause have tried so many times if l press 2 twice it gives me 22 while l need alphabet
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Its doing my head in
さんによる
コメントを追加
How do I get the letters on my phone dial pad ?
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
さんによる
So give me right way
さんによる
Hi just discovered on my phone. Hold down the required key for a few moments and this works.
さんによる
コメントを追加
I went into my actual ‘pair a new device’ part of my phone and it came up with the complete keyboard!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You push the number associated with the letter I need
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 126,801
