メインコンテンツにスキップ
What can I upgrade to make this laptop faster?
What are possible upgrades to make my Laptop work a whole lot better? Thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Ok. Yes, an SSD can greatly improve the speed of your system. RAM can too. But everything in moderation.
So here are the doctors orders:
  • If you need space but speed, I recommend you remove your optical drive, put you old HDD in there and put an SSD in the HDD's place.
  • If all you need is speed, simply replace the HDD with an SSD.
  • If you don't want to sacrifice your optical drive, but need plenty of space, you can either get an SSHD (a small amount of SSD combined with a HDD) or just a large but expensive SSD.
Got a that? Good. Now onto the RAM.
  • Most people don't use more than 8GB of RAM. If your laptop doesn't already have this, this can also greatly help.
  • If your computer has a single 4GB stick, get another 4GB stick to compliment this. If it has any other size less then 8GB replace it with a single 8GB stick.
  • If you really need 16GB, get two eight gigabyte sticks.
If you upgrade to an SSD or SSHD, you'll have to re-install Windows. Use this link to make a bootable thumb drive: https://support.microsoft.com/en-us/help...
For all your needs, Dell provides repair manuals. I got the one you need right here:
Inspiron 15 3000 Service Manual
Hope this helps! If you confused about all this, just tell me how much storage you need and what you'll be doing. I will also recommend parts once you've made a decision.
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
Thank you very much for that. I'll rate but don't know how. Tell me how for I to rate you
さんによる
@reaperxcelerate, you already did by accepting my answer and upvoting it. Thank you!
さんによる
Any idea of the current configuration of ram? Is there only one slot? And there is one 4gb ram in there. Or is there 2 slots with one 4 gb ram that I can either add one 4 gb ram to make it a total of 8 ram or add 8 ram to a total of 12 gb?
さんによる
Hi @ fardi yeung,
According to the specifications the laptop supports up to 16GB DDR4 2133 RAM over 2 SODIMM slots using either 2GB, 4GB or 8GB modules. See p.13-14
So you can have 12Gb made up of 4 + 8. (ensure that they are of the same speed etc)
さんによる
コメントを追加
Upgrade the hard drive to SSD, that is the best upgrade you can make.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
What else can I do? I know I'm able to upgrade the ram to 16GB. What about the graphics card? CPU? Processor?
さんによる
Ram and SSD Upgrades are the only replaceable parts on this machine. Most laptops have the GPU and CPU Soldered to the Mother Board
さんによる
That's it? Nothing else?
さんによる
コメントを追加
回答を追加する
Ryan Montesino さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 5,091
