メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Why is my iPhone randomly opening apps, taking pictures, typing letter
My Iphone is a hand me down but it didn't have any problem up until i received it. It types random letter and opens apps. Sometimes ill knock it a little bit which helps sometimes. I've restarted it over and over thinking that it would solve the problem but it hasn't. Maybe its a screen issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
My micro cracked screen iPad does the same thing.
In fact it locked me out from Apple ID so severe, I had to
have Apple Support live on the phone two different days
to solve it on laptop to get back in,,
Making sure iPad had no access to network..
さんによる
コメントを追加
3件の回答
ベストアンサー
There are a few things that can cause what you are experiencing but yes...I would start with a screen replacement after checking that all the connectors are seated properly. Remember...1. Power off phone 2. Unplug battery 3. keep track of screws that hold the shield on, they have to go back into same hole they came out of 4. when disconnecting the connectors, be gentle...you don't want to knock off little components or damage the flex cables.
Here is a guide that may help you
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
I had the same issue and replaced my iPhone 6 Plus with a new one. It continued to happen so I searched more on the web and saw comments about static electricity... I decided to wrap my phone in dryer sheets to remove the static and it now works perfectly
さんによる
I'll tell my husband to do the same thing Robin.
さんによる
コメントを追加
Maybe the touch issue, reconnect the LCD screen or change a new replacement to have a try.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
iPhone typing by itself -problem fixed. As it was typing crazily, I simply tapped on the little square icon on top, left side of keyboard (next to the microphone icon). It was instantly fixed. Couldn’t believe it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tristan さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 28
今までの合計 59,722
