メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Note 4は2014年10月にリリースされたスマートフォンです。Galaxy Note 4のモデル番号は、米国の種類のSM-N910、SM-N910A、SM-N910T、SM-N910V、SM-N910R4です。
I think its fried; boat transformer
I had my Note 4 on a sailboat in Tahiti. Got some great pictures (that I really want to recover).
She was at 3%, I took the fast A/C charger that came with the phone, and plugged it into the 120V boat's transformer... FWIW, I had been doing this all trip with no problems.
The phone makes the charging noise, I lock the phone, I walk away.
Three hours later, I come back, I see the red indicator light on (which I thought was strange, the phone charges in like half an hour usually).... I unplug the cord, light shuts off, and its shown no signs of life since.
I tried a different cord, I tried using my computer, I got a new battery off amazon, I got an external battery charger (thinking maybe the port was compromised).... nothing
I really want those pictures off my phone, money isn't a serious concern... help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi!
Did you have your pictures backed up in a Google account or something?
The daughterboard that handles charging may also be compromised, so you should look into replacing it, maybe using this guide.
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
Thanks for the reply. I have looked into it. Do you know if a compromised daughterboard would cause the phone to still be totally lifeless even if a fully (externally) charged battery is swapped into the phone?
If is would be expected to work with a charged battery inserted, the only path forward I currently know is:
- Buy a working note 4, and swap the motherboard... see if it works
さんによる
No it wouldn't work even with a new battery, they never do... fuses get blown.
Just make sure you swap the daughterboard, not the main board.
さんによる
Dude, yes! This is my new path forward.
I'll send the photo I took your way if I ever recover it!
さんによる
Alright, have fun and good luck fixing your Note!
さんによる
コメントを追加
Hi Mike,
Just a quick note on photos -
I always set up albums
so that images only exist on SD card.
Maybe you did this as well.
Best of luck on the mission Captain,
especially when each image
has $10k$ value.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks Philscbx, I'll be doing that next time (if i can get her working). Have to wait for the parts to arrive :D
さんによる
I find it odd phone mfg's by default - don't make this a priority for images.
But just by luck, my new LG V20 does have this feature right up front
when creating album,, 'save to phone or SD'.
This has always been a huge step by step process otherwise on every
Phone I have had in the past- IPhone to Samsung.
さんによる
コメントを追加
回答を追加する
Mike Dale さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 214
