メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Why is my thouch ID doesn't unable and home button doesn't work?
Hello guys!
I just opened the iPhone, detached the camera cable and reconnected it, after that the home button stopped working and Touch ID is unable.
I made a reset, restored via DFU mode, but it didn't helped.
How is this possible, because I did not touch anything except the camera cable.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Unplug the battery cable then plug it back in. Turn the phone back on and see if that helps.
You may need to restore the phone again if it's still not working. Make sure you backup any data via iTunes backup before restoring if needed.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I've restored my phone twice, but touch id still unable. I'll try to unplug the battery cable.
さんによる
unfortunately, it didn't help me ((
さんによる
コメントを追加
When you opened the phone there should be a small ribbon cable that went from the screen assembly to the logic board that connects the home button (and the touch ID) to the logic board. Unplug and re-seat this then make sure you restart the phone (unplugging the battery and re-plugging it might also be a good idea) this should force your phone to reload the hardware and detect the home button again. I have done this several times to older versions of the iPhone. I think simply opening the case can sometimes loosen the cable enough to cause the home button to stop working.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
unfortunately, it didn't help me too ((
さんによる
コメントを追加
回答を追加する
Viktor さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 6
今までの合計 132
