phone stuck on service logo screen
i have a zte grand x max 2 and it now stuck on the cricket logo screen and will not boot any further. is there a way to fix it or is my last option to do a factory reset?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Well, and I apologize I don't know exactly how it works. You can try OD1N, which you'll need the correct files to soft boot the device. If that doesn't take you'll likely need to do a restore
このアンサーは役に立ちましたか?
Wait for the battery to die and than try again. If this doesnt work i think u have to do a factory reset
このアンサーは役に立ちましたか?
I tried letting it die and tried turning it back on and it is still frozen on the logo.
このアンサーは役に立ちましたか?
my ZTE A320 blade stuck on the logo
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 6,412
3 件のコメント
Before doing a factory reset try wiping the cache partition
Jimfixer さんによる
Having the same problem right now. What did you end up with?
Troy さんによる
My ZTE Blade a7p won't work it's turning off and on won't respond to force restart or hard restart
ZTE Blade a7p won't be work さんによる
