メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
6s plus No boot
I got a 6s plus that came in dead, aftermarket battery. Connecting to charger pulls 0.4A but no boot. Connecting to DC power supply no amps pulled and it will not boot either (it actually pulls 0.02A before promt to boot but I tried it on my own, known good working 6s+ and it does the same)
I thought half an amp is wrong, it should be 1A so I replaced tristar with a new one but still doing the same.
All power voltages I could think of are present. No water or physical damage I could see.
Any clues?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
How are things looking on VCC_Main?
さんによる
All voltages I measured are there: vcc main, nand, tristar and around pmic power rails are there. Couldn't find any shorts whatsoever
さんによる
コメントを追加
1 件の回答
ベストアンサー
First things first...does iTunes recognize your device if you plug it into the computer? We need to eliminate the possibility of a bad BL or LCM driver. You may have already checked that but we don't know based on your comments.
Assuming the BL/LCM circuit is good (as is the screen), the have you checked ALL of the PMIC output voltages (there are 28 of them)? Start with the main ones like CPU/GPU/SOC/FIXED/SDRAM/SRAM/PP1V1. TRISTAR requires the presence of PP1V8_SDRAM. No need to enumerate them, just tell us which ones, if any, are out of spec or not present.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
I did try to plug it to itunes, it doesn't recognize it. Screen is good, tried it on my own 6s+ and it worked just fine. Current draw on DC power supply shows virtually no amps, so it's not trying to boot. I'll have to make a checklist of the power rails, but all that I measured were present. Will report back if and when I find anything suspicious
さんによる
Any update on this problem i have one with same issue.
さんによる
No luck Tim, the client wanted it back so I lost this was a no fix. Too bad, I really wanted to solve it
さんによる
コメントを追加
回答を追加する
Rodrigo Maero さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,129
