What happened to my phone?
Screen popped up saying 'Stock Android has crashed', so I restarted my phone. Now my phone will not get past the MetroPCS screen. Any help? I've restarted it several times.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try this https://www.youtube.com/watch?v=ssX1ULxV...
At 1.19 pause the video and you will see it says wipe cache partition do this and press the power button .This will clear the memory and allow for a clean boot if this gives no joy then follow the rest of the video and factory rest the phone but understand if you do a factory reset then you will lose all data . Hope this helps
このアンサーは役に立ちましたか?
Hi There,
First, Change Another battery and see if it passes the Metro PCs screen. If does good for you, If not then:
The software on your phone has corrupted. you might have to restore the software. Will recommend to take to a repair store or take it to Metro PCS and have them check it out for you.( I dont think so they will help you out but might give you a warranty replacement option).
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 1,184
