Removing the kenmore 90 series agitator
How do I remove the agitator when an article of clothing is stuck under it?
Once the article of clothing dries out, it should shrink a bit and might be easier to remove. Try waiting a little while.
Can you post a photo? Here's a video of a normal removal, without clothes in the way:
If that doesn't work, you're probably going to have to force it. You may need to cut the clothing off to remove the pressure, or you could break the plastic.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 11
今までの合計 1,888
