screen repair liquid adhesive
what is liquid adhesive for digitizer screen?
We generally recommend pre-cut adhesive strips like this iPad 3/4 Adhesive Strips rather than liquid adhesive. It's quite a bit easier to apply.
We also do testing with our adhesive strips to make sure that you can remove the adhesive afterwards (in case you ever break it again and need to re-open it).
このアンサーは役に立ちましたか?
so do u mean loca? liquid optically clear adhesive. if so i would recomend you dont try to use this on an ipad or any screen with a backlight for that matter. it will only cause you more headache.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 81
