loose laptop hinge,how to tighten?
my laptop hing has become loose,how to tighten it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I'm not familiar with this laptop but most of the time it's not the hinge that's the problem but the plastic it's screwed to. Sometimes if you do a fairly full disassembly you can repair the cracked plastic with epoxy glue or thermoplastic but it's not always possible.
このアンサーは役に立ちましたか?
u just need to open the laptop and tight the hingers screw simple but dont open it go to some professional.
このアンサーは役に立ちましたか?
Its confirm that there is no solution like Elfy or super glue to make it right at place for a long time ..you need to replace hinges by paying amount of 1800 at any Haier facilitation center.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 1,598
