メインコンテンツにスキップ
A followup to the LG V10 smartphone, similar to the LG G5, released on September 29, 2016. The LG V20 can be distinguished by the model numbers F800, H910, H918, H990 DS Dual, H990N Dual, H990T, LS997, US996, and VS995. It is available in titan, pink, or silver with 32/64 GB of storage.
51回答 すべてを表示
Date and Time on Sleep Mode
My battery seems to be draining pretty fast. Doing whatever I can to remedy it. My question is, I just bought this V20 Unlocked and when it is in sleep mode, it constantly displays the time and date at the time, it's very dim but you can still see it.
Can this be removed or is this time and date on the sleep mode built into the phone where you can not disable it. Please help.
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
You'll want to disable ambient display. Go to settings, display, then switch off ambient display. That should cut it! Also look at battery usage in settings and report your battery usage data.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I went to setting then display and I don't see ambient display
さんによる
コメントを追加
Step 1: Settings
Step 2: Quick Cover Case
Step 3: Second Screen Settings
Step 4: When Main Screen is Off
Step 5: Toggle the “When Main Screen is Off" from On to Off
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ron Gacek さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 675
