Why is my screen dark?
My LG tablet charges and turns on but screen is so dark can barely see and appears not to respond to touch..how do I fix?
Mrs. Williams sounds like your display assembly is failing. The dark LCD could be because of bad backlight and the no touch situation could be a failed digitizer. Of course there is always a chance that this is caused by same disconnected ribbon cables etc. For that you would have to disassemble your tablet. Use these guides to work on it and let us know what you find. You can post images with your question by following this guide iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 12
今までの合計 1,237
