メインコンテンツにスキップ
ヒューレットパッカード(HP)は1993年よりパーソナルラップトップコンピューターの製造を開始しました。
3332回答 すべてを表示
SMART Hard Disk Error Windows 10
I was in the middle of playing a game on the laptop when what I assume was the drive making a noise similar to those musical floppy drive videos (Floppotron) The computer soon crashed and directed me to a black screen that said:
"SMART Hard Disk Error
The SMART Hard Disk check has detected an imminent failure. To ensure not data loss, please backup the content immediately and run the Hard Disk Test in system diagnostics."
The problem is that when I attempt to run the test it tells me:
"No hard drive installed. Please check that the power and data cables are connected properly."
I have no idea how to do that, and if it will help at all. I need step-by-step instructions.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
What is the laptop model? You will need to replace the hard drive.
さんによる
コメントを追加
4件の回答
最も参考になった回答
It appears your hard drive has failed. you can try to boot into windows and backup your data onto a separate drive, but your hard drive may be dead. You will need a new one. if you can include more details we can probably give you a link to where you can buy it.
If you are sure your hard drive is broken and AFTER replacing it:
On the upside, after replacing your hard drive you can disassemble the old one since it's broken! Teardown maybe?
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
@captainsnowball If you read the OP, the message appears "No Hard Drive Found".
This means the hard drive cannot be detected. Probably the Motherboard on the drive fried or motor failed, but either way, the computer will not be able to boot back into windows.
さんによる
oh hmm little details can make all the difference.
さんによる
コメントを追加
It would appear that the drive is dying. Stop trying to power up the computer and force the drive to do more. You should clone the failing drive to another drive ASAP especially if you want to keep your data. Using the failing more will only lead to bigger disasters especially if you want to keep your data. BTW keep the drive powered off as much as possible until you are ready to clone it, physically disconnect from the machine if you have to.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I was playing a game when my laptop just stopt went to loading screen then as i left it it then took me to
Smart disk error 301 somthin somthin
And every time i boot i get that message plz help
That will be great if u do reply
さんによる
Hi there,
Thanks for comment, the error may indicate that your Hard Drive is failing and needs to be replaced.
First of all, remove and then reconnect the Hard Drive.
Next, enter the bios menu. Under the Advanced or Diagnostic tab you should find the facility to run a test on the Hard Drive.
Hope this is helpful.
さんによる
コメントを追加
Just push f2 button on the key board then wait till a menu pops up, then click hard disk test then click start test
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Are you experiencing the dreaded I/O Device Error on your external hard drive? This error means that your hard drive is failing, and if you don’t act fast, you could lose all of your data. This guide will show you How to Fix External Hard Disk I/O Error in Windows.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Battlecast Vel'Koz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 23,320
