メインコンテンツにスキップ
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
20回答 すべてを表示
Touch screen partially works
Touch screen has area where It doesn't work so I disconnect and reconnect more times the two flat ribbon cables which link touch screen to board but nothing!
Suggestions please?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@rickyleroy anytime you have part of a touchscreen that is not working, you most likely have a failed digitizer. Replacing it will fix your issue.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
If I work with virtual keyboard and I push down specific key, character is not lightened and no symbol is written while if I press it with more pressure another near character is typed.
I avoid this behaviour rotating tablet of 90 degree.
What other test can I do?
さんによる
Where can find guide to replace touch screen for me173x?
さんによる
I replaced touch screen. Now I noted in landscape mode it works fine while in portrait (vertical) mode, with Asus text in top area, the last bottom strip doesn't work where there the 5 five bottoms. If I rotate device of 180 degree the bottoms works so I suspect specific area has issue. What can I do?
さんによる
コメントを追加
回答を追加する
Riccardo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 473
