メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
電子キーボードの修理および分解ガイド。
Casio Sk-60 replacing missing on/off button
画像
Hello, i am new here!
I need help with this vintage Casio Sk-60 keyboard, it needs a replacement for that missing (slider) switch. I would love to repair it!
I know how to solder simple things. Adding a lineout or connecting two cables ;) but i am totally lost on this one.
画像
Here you can see on off i prepared for the keyboard. When it will work i will drill a bigger hole for it.
画像
Thats the inside of the keyboard.
画像
And here you can see the part where the switch was. The upper position was (On)
I also found this sceme here, but i dont get it...
画像
I was hoping that maybe someone here sees the solution right away and can help me out. That would be great!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
@prokrastinator what you posted is not a schematic but a board layout view. It will not tell you how to connect a switch. You need the wiring diagram for that. I got this from the manual
画像
Now you need to figure out on the board view which point is what. Going back to your image and checking the layout and schematic it appears that connecting a switch the way as pointed out in my pictures should work.
画像
画像
画像
always double check with a meter to make sure that you do not close any power to ground circuit.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you <3
That helps a lot!
さんによる
コメントを追加
Hi,
I got same problem but i don’t understand, is it solder a spst switch between vcc and vdd with 777 on center ?
Help much appreciate
thanks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
- is it solder a spst switch between vcc and vdd with 777 on center ?
- no. it is solder a double switch, one part between vdd and 777 with what ever it is on center (those longer graphite bars are center). another part is between vcc and nothing with the other longer bar on center.
さんによる
コメントを追加
回答を追加する
Prokrastinator さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 1,568
