メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
It doesn't recognize my disk
I spilled water and eventually reached my PlayStation and only the bottom of it got wet. I dried it, but when I tried to play the game that was already in there it was saying " insert disk in order to start this game" so I took the game out, cleaned it and put it back in. Now it says " Unrecognized Disk. " When ever I put the disk in there it spins , stops, makes a clicking noise, then spins again till finally it tells me it doesn't recognize my disk. I've read solutions saying to clean my opticle drive PBC but I don't kno how to do that , I'm scared if I tried I would mess up something , please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
It sounds like you probably need to replace your optical drive. Here is a link to a guide telling you how you can do it. All the tools you need can also be found in the guide along with links to where to buy them. Good luck!
PlayStation4 光学ドライブの交換
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Replacing your disk drive won't be too difficult if you follow along with a guide, just remember not to be scared of taking it apart! You should still be careful, but don't let fear of breaking it stop you from fixing it, I'm sure you can do it. The guide has been posted already, but you may need to check which PS4 you have and which disk drives are compatible with it. Here are a few:
PlayStation 4 Optical Drive (currently out of stock)
https://www.newegg.com/Product/Product.a...
https://www.amazon.com/KES-490AAA-CUH-10...
Optical drive without circuit board assembly compatible with a PlayStation 4 console.の画像
製品
$39.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Myra さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 17
今までの合計 241
