My Tv has a big crack in it
My Tv has a big crack in it and was wondering if and how I could replace the tv screen?
Really easy, its only 4 screen on rear cab and 2 screews on PSU.
Just be carefull then opening rear cabinet.
このアンサーは役に立ちましたか?
Were can you buy them from
@jordan_bolt yes you could replace the screen, if it were available. LCD screens that size are not easily found and will cost you more than a new TV. You will have to take the back of your TV and find the manufacturers label on the panel. Then use that number to do a search. Only other option would be to find the same model TV as yours but has other parts broken. Then harvest the LCD from that TV.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 5
今までの合計 3,040
@jordan_bolt I have a question. is TV screen broken or it's panel?
my TV panel broken too but it broke on its own.
Abolfazl Jafari さんによる
