メインコンテンツにスキップ
The HTC One Mini 2 was released in Europe, the Middle East, and Asia in May 2014. The HTC One Mini 2, model number M8MINx, features a single rear camera and 16 GB of storage. The HTC One Mini 2 is much like the HTC One M8 but smaller and less expensive.
21回答 すべてを表示
will not charge, or turn on
my phone started to flicker for no reason while I noticed the battery was red, then it just went off, since then nothing has made the phone turn on, I have left it charging for a while and sometimes I do get the red light reappear with the charging symbol but once that shows after a short while it goes away again, I have tried the calibration and all sort of combinations., I don't know what else to do. any ideas?
Update (08/14/2017)
now i get a blue screen after the logo and then it gos black and gos back to charge.....
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
it was on the bathroom side last but only for like a few seconds, I have already tried calibrating it, but it doesn't work as it takes hours before the charge sign pops up and as soon as I touch the powerup and down and power it goes black and stays off still
さんによる
コメントを追加
1 件の回答
Did you try a different cable? That could be flaking out and not charging your phone properly.
You may need to do a hard reset on your phone. Is the battery life worn down on it? May need a new battery.
Lastly, was it exposed to any moisture?
Hope that helps
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
回答を追加する
Prestige さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 102
