I crank the engine and no Start fast
I crank my engine but no Start fast and when i stop and teñirse the brakes and pres gas the car no have power.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Your car sounds like it needs a tune up . You may need to replace the air and fuel filter . New plugs and wires as well , a new PCV valve will also help. If the engine is throwing any codes they should also be addressed . Do you have any MIL lights on on the dash ? If so get an OBDII reader and find out what systems are effected. Service your car and it will run well ignore the maintenance and it will run like crap . Hope this helps
このアンサーは役に立ちましたか?
BTW don't forget regular oil changes
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 98
