メインコンテンツにスキップ
The Asus ROG Strix GL702VM-BHI7N09 is a gaming computer released by Asus in January 2017. It can be identified by the serial number on the bottom of the keyboard.
22回答 すべてを表示
Why is powershell (the main operator of Windows) not working properly
After some time I use my computer then I get this message: powershell stopped working. I don't close it because I don't want to find out what happens. I also removed all the viruses in my computer
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Person -- What version of Windows are you running? Powershell is just a feature of Windows, not the "main operator."
さんによる
コメントを追加
1 件の回答
ベストアンサー
You can shut your laptop and restart it. Power Shell is similar to the command prompt but more capable. If you continue to get the message that Power Shell is not working then you can open a command prompt (with admin) and type the following SFC /scannow, this will check and repair system files. If this doesn't work then try using Windows Restore to reload the operating system. Be sure to back up your data files before doing a Restore.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you, the scan found a corrupted file and now i dont have the problem anymore
さんによる
oh wait, now ive got two, didnt help, neither step 3
さんによる
コメントを追加
回答を追加する
person さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 640
