メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2396回答 すべてを表示
締切られた回答
Broken Digitizer ribbon. What now?
So, I took apart my iPhone 4 using an iFixit guide to get to the home button to fix an issue with that (I just needed to clean around it). I accomplished that, but while I was reassembling it, the end of the digitizer cable snapped off.
Do I have to replace the entire display assembly now? Is there another option because I don't really want to spend $150 to fix this...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Thanks. I hate to admit this, but I actually closed up the phone and took it to Apple and said that the touchscreen just stopped responding. After determining it was a hardware issue (I just played dumb and didn't say anything), they swapped it out...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
yeah you would have to purchase another display assembly. unless you're a very professional technician that can fix tiny ribbon cables.
i had the same problem as you did, and had to purchase another assembly...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Did apple try and repair the phone first, or did they just replace it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 6,174
