メインコンテンツにスキップ
2.0GHz, 2.3GHzもしくは2.6GHzクアッドコアIntel Core i7プロセッサ (Turbo Boost 最大3.8GHz) 6MB共有L3 キャッシュ付き。
580回答 すべてを表示
Sourcing PPBUS_G3H Fuses (F7140 + F7141 820-3662)
Been getting a lot of these recently with F7140 and/or F7141 being blown, so I have pretty much used all fuses from donor boards. These fuses are an odd spec (8A 32V 0603) and I have not managed to get them anywhere. They are also only found on the 15" Retina boards.
Anyone know where I can get these from?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@reecee that is a bit of a tough one since you are the other side of the ocean. A definite fit is a 0603SFF200F/32 made by Littelfuse. I do not know who would sell those where you are. Over here you can get them through places like like this one.
If you do not mind the high shipping, then this one should work as well
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks for the links. The first one seems to be rated for 2A not 8A, however the 2nd one is what I am looking for (although pricey!).
I'll keep having a look around, just don't understand why these seem to be so difficult to get hold of :(
さんによる
コメントを追加
回答を追加する
Reece さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,426
