メインコンテンツにスキップ
2016年6月発売。モデル番号はA3003(EU)、A3000(中国と北米)。(以下の情報より https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
Sudden shut down and not able to switch it on
I was using my oneplus 3 and it randomly shut off. It wont respond to anything. Battery charged 90% enough for 10hrs . Tried pressing power button and volume down buttons same time, for factory reset it wont respond. I faced no such issue earlier. Everything was fine till now. Please advise.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Wait till next day for the battery to drain completely .then charge again.
さんによる
I kept my phone in fridge for 20-25 min. then tried to plug in to dash charger n started pressing on/ off button several times and tried plugging unplugging cable while pressing on/off button n mobile got switched on
さんによる
コメントを追加
3件の回答
最も参考になった回答
Mine does this. The way to fix it is press the ON button while plugging it it and keep it held down while you unplug it and then plug it back in again. That always fixes mine. Don't ask me what causes it to shut down in the first place though.
このアンサーは役に立ちましたか?
スコア 7
8 件のコメント:
OMG this really worked for me! I have no idea why, but it does!
I only registered for this website to say thank you and confirm this solution :)
さんによる
Worked for me too. No idea how does it work. And yes I also signed up to say thanks :)
さんによる
How its work anyone tell me.
さんによる
I just signed up to thank you! You saved me a lot of trouble! I am eternally grateful to you!
さんによる
Can confirm this works on a 3T as well. I don't know how you figured this out, but THANK YOU!
さんによる
3件以上のコメントを表示
コメントを追加
I am using one plus 3 phone but it often switched off automatically . And when I gng to switch on some times it's not respond and some days 10-15 days working good and some days daily 10-15 times is going on switched off pls anyone give suggestions wat I will
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Have you tried the unbrick guide from the OnePlus forum? It may be a software issue, and if so then the first method in the unbrick guide should solve it. :)
https://forums.oneplus.com/threads/guide...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
POTHUMUDIS さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 35
今までの合計 11,475
