How to put the to halfs together
The back half containing the bottom key board fell of there is still the wire connecting the two but the two parts are disconnected.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If the two halves have come apart it means the plastic slide has pulled through . I have check my usual sources and there doesn't appear to be replacement parts available. There is quit a few phones similar to this on eBay and Amazon that don't cost much, you can buy one for parts . May actually be cheaper than buying the part new This is a tear-down video .
https://www.youtube.com/watch?v=Kdh0LIOa...
You'll need to slow it down if you can. for some reason the poster thought it would be a good idea to speed up the video . hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 323
