メインコンテンツにスキップ
Model MD2614u / AMD Turion X2-64 2.1GHz dual-core processor
black screen when powering up, Can see shadows behind it?
My child was watching Netflix on the laptop. After watching the movie, she closed the top off the laptop down. I went and opened it back up and there was a black screen and I could see shadows of the icons and a pop up saying windows was not properly shut down.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
Can you shut it down and restart. Sounds like your backlight is out. Looks to me like you need either a backlight or a new inverter. Your LCD is okay as long as you can see your icons etc. Of course first try to shut it off and restart after and see if that will resolve the issue. http://www.batterycentury.com/gateway-md... has the inverter. Hope this helps to clarify this a bit. Good luck and let us know what happened.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
+ I agree and would check the inverter first
さんによる
コメントを追加
My display is doing the same thing. The backlight comes on when booting up and goes off at windows login. Any suggestions?
Update
I fixed it. Anyone having this problem just restart in safe mode by pressing F8 while booting up, then using the arrows go down to where it says restore windows to a point where it loaded properly (not sure the exact language)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jacquie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,646
