メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone won't turn on
I have an iPhone 6 space grey with a cracked screen. When I tried to turn it on, it showed nothing on the screen. I put it on charge and it showed the battery icon and then a few minutes later the apple logo for a split second, then to a blank screen.
I could see the screen was actually on due to the cracks showing the light through, but after a few minutes there was still nothing.
Is it a battery issue, or is it something else?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
The battery icon now flashes instead
さんによる
コメントを追加
1 件の回答
最も参考になった回答
The first step is to differentiate between these possibilities: booting as normal with no image vs autobooting to DFU. Check to see if the phone is detected by iTunes. If iTunes asks you to enter a passcode on the the device--the phone is normally booting. Given the history this points first to bad display--replace display.
If iTunes recognizes the phone as "there is a problem detected with your phone..." then it is autobooting to DFU. Try to update then restore software and see if the phone will pass restore. If not, then rule out parts problems, and then consider board level issues that may be solvable.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Daemeon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 49
