メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年7月28日に発売されたNew Nintendo 2DS XLは、2DS携帯ゲーム機の技術的に改良されたモデルです。Nintendo DSシリーズの9番目で最後の再設計モデルであり、元の2DSモデルよりはるかに大きく、トップ画面での立体視3Dゲームプレイ機能を除いて、アップデートされた「New 3DS」システムラインのすべての機能を備えています。
How do I replace the Bottom screen and Top Screen
Hi, someone through my bag, and it dropped onto a tree stump. Both of the screens are damaged on my 2ds xl, the top one has lines going through it and the bottom touch screen is fully smashed, and won't work at all. Everything else works fine, the controls, speakers and all that but I just want to know weather it would be better to buy a new one, or to repair the one I have already.
Thanks and Cheers of all of you who have an answer to this problem
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
4 件のコメント
I have a problem like this,the bottom screen of my 2ds Xl is not functioning due to a dent and scratches. I'm only a kid so no money,how do I fix the bottom screen?
さんによる
You’re gonna have to buy a replacement screen. Luckily, not too much. Probably $15-$30.
さんによる
My bottom screen works fine but the top screen feel off do you no how to fix it?
さんによる
So exactly the same thin as Liam but the top screen also I lost one of the connectors so I can not reattach the top screen do you know if I can get a replacement?
さんによる
コメントを追加
3件の回答
ベストアンサー
Hi!
While you can replace the bottom screen, the top one is, as @johnwp mentioned glued to the entire front panel.
You could follow this guide if you wish to fix your console yourself, you will only need a good source for the bottom LCD & digitizer and for the upper front panel. You could try AliExpress or eBay I guess.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Where would you find a replacement for the top screen? eBay has none for sale.
Thanks
JB
さんによる
コメントを追加
The top LCD is NOT glued to the entire top glass. There is adhesive around the paremeter of the LCD holding it to the glass. If you haven't actually taken it apart, please do not give people the wrong information.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I don't think the top screen can be easily replaced. The top screen is a whole unit. There is liquid between the plastic and LCD. If you take the LCD away from the plastic piece it will only further damage it. As far as I know the only course of action is to send it in to Nintendo. Can anyone verify this?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Oh, my brother smashed my top screen while I was sleeping, I have CFW, can I send
it to Nintendo even though it is hacked, and how much will it cost?
さんによる
If you can blindly navigate GodMode9, than you can uninstall CFW easily. It will cost $50 to send it to Nintendo, not including shipping.
さんによる
Weird seeing SirNapkin here, also, I bought a new screen for $60
さんによる
There is no liquid in between the plastic and the LCD, you cannot easily remove the LCD from the chasis without damaging it. But you only want to remove it when its damaged anyway. Can it be replaced, !&&* yeah it can
さんによる
コメントを追加
回答を追加する
Recco waite さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 34
今までの合計 7,468
