メインコンテンツにスキップ
14.1", Intel Core 2 Duo T5450-powered laptop by Acer
10回答 すべてを表示
Can I replace my LCD screen or repair it?
The outer part of the screen is intact but the inside is cracked. Also before this happened my screen used to flicker and when I need to reinstall windows I can't see what I am doing.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
Faian Jamil, if your LCD is cracked I believe that you will definely have to replace it. As for the issues that you had prior to this, it could be a bad inverter a bad backlight and/or bad cable. You will have to reasses this when you have a known goodworking screen. The LCD is available here http://www.blisscomputers.net/acer-exten... and multiple other places. Good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If the screen is cracked, you cannot repair it. The screen has to be replaced and it's easy to do.
All you have to do, is remove the screen bezel and disconnect the screen.
The following guide explains how to fix broken hinges but you can use it for replacing the screen too.
http://www.insidemylaptop.com/replace-br...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
They best way would be to replace the screen by using a service manual or online tutorials. You can order new screen online using Amazon or eBay.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes, this is very easy to do. You can find instructions how to replace a laptop screen and both glossy Acer Extensa 4620 screen and matte Acer Extensa 4620 LCD display on NotebookScreen.eu
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 2,572
