メインコンテンツにスキップ
The Toyota Camry is an automobile sold internationally by the Japanese manufacturer Toyota since 1982, spanning multiple generations. Originally compact in size (narrow-body), later Camry models have grown to fit the mid-size classification (wide-body)—although the two sizes co-existed in the 1990s.
Why the car is consuming more fuel
The car showing no other symptoms.but the fuel consumption is double than usual.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
A more detailed question should be asked. What type of engine. Is the check engine light on. When is the last time you had a tuneup? My guess is never...
Double the fuel consumption you either have drag (issue with the brake system, seized calipers), sensor(s), fouled plugs, air filter clogged, vacuum leaks, a fuel leak, under inflated tires. Although it won't be a tire issue..
My guess is start with a tuneup, plugs, filter etc..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
alimoosagarage さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,243
