Plays way too loud
Playback volume has gone wrong, level 1 is deafening
If you go from the DVD player into another piece of equipment, like a stereo tuner or an amplifier, make sure the volume on that second piece of equipment is volume low. Without knowing your setup, it sounds like you might be sending a low signal into something else that is turned all the way up.
It's easy to forget about the amp part of it.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 121
@alholroyd what exact model is this? Is the volume still adjustable or does it just play loud without being adjustable?
oldturkey03 さんによる
