メインコンテンツにスキップ
Smart smoke detector from Nest Labs, the creator of the Nest Learning Thermostat.
3回答 すべてを表示
Why does the smoke alarm go off for no reason.
The smoke alarm goes off for nothing. It's summer here, all the doors are open, not a wisp of smoke around, yet it goes off several times a night. My question is can I take this apart and clean the sensor? The unit is a few years old, and we heat with wood so I'm wondering if there's a buildup on the sensor that can be removed. Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Thanks for the answer.
Checking the batteries was the first thing I did and they all tested good. Right at the top of the scale good, but. I might try putting in a fresh set just in case.
Thanks again.
さんによる
On a summer night with windows open, small insects may come through the screen. Attracted by the light on the smoke detector, they can set it off. Spray screens and the detector with bug spray. Yes, I learned this the hard way!
さんによる
Please note that many issues are when you do not replace with Energiser L91 batteries. This is the only battery that is recommended for this device.
I had no end of issues when putting new Duracell batteries with reports of low battery etc with 100% good Duracell batteries.
Nest support states that only Energiser L91 is supported.
さんによる
コメントを追加
3件の回答
選択されたソリューション
Change the battery. A low battery will trigger it.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Hi there.
Your anwer is quite short.
Of course tlyour statement could be true, but my second thought is:
A Nest Protect is permanently connected to AC power. The 3 lithium cells have a lifespan of at least 5 years.
Moreover, the NEST Protect designers would be quite stupid to sound a firewarning because of a battery-faillure, instead of a warning that says: ‘please replace batteries’.
Go figure: there will be not even ONE test engineer that will let such a stupid design flaw unnoticed!
I had this false alarm problem already in 2 unit (both version 1) only after 2 years of continuous operation.
One of them has been sent back to Nest, and they were so nice to send me a replacement u it (version 2 !!)
The second Nest Protect (verdion 1) failed 1 month ago. To test your ‘replace batteries’ solution, I wwill just put new lithium batteries in that second failed unit, and will for sure report back about the result.
cheers
robbert
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Just for clarity:
The batteries in these are for backup purposes only when the main power fails. All detectors that are hardwired that have battery backup work this way. The user will be alerted to the batteries starting to fail so that they can be changed. While the lithium batteries have a 5 year or greater life, their actual lifetime will depend on how much they are used. The detector will have a monitoring circuit to detect a failing battery.
While I couldn't find it directly, since the detector has a "split-spectrum" detector, I am assuming that it is a photo-electric detector which is less prone to false alarms due to steam and dust. If the detector continues to produce false alarms, replace it.
さんによる
コメントを追加
Although this is an old question I'm sure you are not alone in asking it. No, not only is it ok to open it and clean it,. You should do so periodically dust, Insects etc accumulate over time and it is recommended to use the brush attachment of your vacuum cleaner on it periodically ( twice yearly, like minimum testing and battery replacements where used). While you're about it take a look at the date of manufacture you may find an expiration date too, if you do, DO NOT ignore it. Unlike many other things it isn't just to make you buy a new one for no reason... they expire. If you are using ionization type detectors (general advice) replace or augment them with photoelectric detectors as soon as you can, ionization type detector's Fail to alarm 30% of the time in actual fire conditions. Photoelectric detectors are more likely to wake you in the smoldering stage of a fire when smoke inhalation kills most victim's. (Im a retired Fire Chief) As to why it goes off, dust, wind, strong chemical odors, paint fumes, insects inside it, smoke from burnt toast, etc. steam from a bathroom or sink, fluctuations/ interruption of power, loose electrical connections, all might be causes.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Robin Wilkinson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 48
今までの合計 11,300
