メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The BlackBerry Priv is a slider smartphone developed by BlackBerry Limited. Following a series of leaks, it was officially announced by BlackBerry CEO John Chen on September 25, 2015, with pre-orders opening on October 23, 2015 for a release on November 6, 2015. It can run up to Android 6.0.1.
Wi-Fi Mac adress stuck at 02:00:00:00:00:00
Hello everyone,
For a few days now, i can't activate le wi-fi on my BlackBerry Priv. When I go in the option to activate the wi-fi, it keeps loading and it show no wi-fi in the list. After a few research, i've discover that the MAC address for the Wi-fi is stuck at 02:00:00:00:00:00.
Here is a liste of what i've tried to solve the problem (with no sucess):
1- Reboot the phone a few (lots of) time
2- Pull the sim card out, no wi-fi
3- Replace the sim card
4- Let the battery drain until the phone shut-off and charging it again
Hope someone will be able to help me , cause i kind of like this phone :(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
最も参考になった回答
Hi Stephane,
Can I ask if the phone was purchased second hand? Also, is the phone Rooted?
If so I would recommend wiping the phone fully, if that doesn't work is flash the firmware back onto the device.
It seems that the MacAdress is either Spoofed on a software level or someone has tampered with the phone's root files...
Thanks!
Ben
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hi Ben,
thanks for the quick reply !
I've purchase the phone second hand directly fron my provider and it as not been rooted. So I think the next step before heading to the repair shop is to do a factory reset.
Stephane
さんによる
My iPhone 11 shows the same MAC address. Should I be concerned and if so, why?
さんによる
Hi Ben my phone is the same my Mac is 02:00:00:00:00:00 no matter what device I use I need help
さんによる
コメントを追加
My iPhone 11 shows the same as well as my 6s. Should I be concerned? If so, why?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi Stephane, were you able to solved it? I have a One Plus 2 phone with Android 6.0.1 and weeks ago just happened that to me and I do not know how to fix if.
Regards.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi guys my priv is the same. Just shows loading but cant switch on the wifi and this problem drains battery so fast bcuz loading continues all the time
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stephane Pepin さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 48
今までの合計 11,251
