CPU Upgrade, Why won't it now boot?
Help!
This is what happened to me and what I have done so far.
iMac 2013 27" 3.5GHz Nvidia GT780M 4GB (This may or may not be important)
So the hinge failed on this machine and, knowing my way around the iMac and other machines, I decided to change it myself. Having purchased a new hinge and the required strips to reseal the machine once I'd finished I proceeded with caution.
Everything went smoothly.
New hinge in place I thought - well whilst I've got it stripped downs so far, I may as well replace the thermal paste with some Arctic Silver 5. So I took the heat sink off, cleaned it up and reapplied.
On this model you have to put the CPU in the socket put the 'gunk' on. Put the heat sink on and then invert the whole logic board to insert the screws and spring from underneath.
Disaster! The CPU slipped and I wound up crushing the edge of the chip!
Don't panic, stiff upper lip and all, lets get a new CPU before my wife finds out.
Amazon to the rescue. Now I found this thread and looking at the costs and delivery times I purchased the 4790 (Not the K) instead of the 4771 that was shipped in the machine.
Put it in and reassembled. Put in the power cable - 1 light. Pressed the start - 2 lights ..... ..... ..... ..... .....
I understand it the LEDs are as follows:
LED 1. Trickle power
LED 2. Start button pressed - Main power on
LED 3. GPU found
LED 4. LCD found
So, I draw the conclusion that the mother board is damaged. (Seems logical to me). Ebay to the rescue. 4 days later a new mother board arrives with no CPU. i've just spent the afternoon switching the motherboards and CPU.
Exactly the same result as the old logic board. So maybe original the logic board is not damaged after all. Now I have (apparently) 2 functioning logic boards and 1 CPU (4790) and they don't want to play.
Can anyone shed light on this?
In total I'm down over £600 and still don't have a working machine. Worst I don't know why.
Trying to predict the questions that may come.
Light 1 on when power cable connected
Light 2 comes on
Fan spin up
Light 2 goes out
Fan stop
Light 2 comes on
Fans start
HD spins up
Fan spins faster
Fan reaches take off speed......
この質問は役に立ちましたか?
1件のコメント
Your systems specs: iMac 27" 3.5 GHz i7 (Late 2013) - CPU Apple used in this model is a I7-4771
Dan さんによる
