Not Charging Because of a piece called B628
When I Repair The Charg Socket I got lost In positive and negative
Then The piece named B628 damage.
I can not change it because I do not have Hot Air,
but is there another solution to make the Power Charge the phone when i connect Him?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント:
@gemyelgeneral post some pictures of what you are looking at. Use this guide iFixitでの質問に画像を追加する方法 so we can see what you see.
さんによる
thx
I have uploaded the pictures
Can I take it away?
さんによる
How do you know it isnt working anymore? And you can remove it with a soldering iron, ive removed much smaller chips. Just hold it with pliers or tweezers and heat all the pins until it releases
さんによる
Well but after removing it the Power does not feel the phone connection to be charged
さんによる
The phone probably wont charge anymore as the B628 appears to be a voltage regulator. You can try replacing it but most power banks arent worth repairing. Your best bet is to save the batteries for future projects and save the other parts like the LEDs and USB ports
さんによる
1以上のコメントを表示
コメントを追加
