メインコンテンツにスキップ
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
20回答 すべてを表示
Not charging after I dropped the S7 edge in wet sand
We were taking pictures at the beach and i accidentally dropped my wife's S7 Edge in some wet sand. We rinsed it off in fresh water and let it dry as we always have even with my S8+ when i used it in salt water. Her S7 Edge started acting up a little bit with charging, it was on and off and would not stay charging. She thinks it may still have sand in the port but i cleaned it out thoroughly. Anyone know if this could be a permanent issue with the phone or do we just need to keep attempting to clean it out?
PS: Wireless charging does work
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi Brian!
I'm sorry to hear about your phone. My guess is that there's sand still blocking the port and/or that it needs more time to dry out. I've submerged my S7 edge in a bathtub and it took 2 days for the speakers to sound clear and about a day and a half for the charging port to function again. In the meantime, I used wireless charging.
To clean out any remaining sand, I'd use a can of compressed air (be sure to keep it upright). If you've cleaned it out sufficiently and are confident you dried it out as much as possible, there's a chance the charging port was damaged to the point of needing repaired. We do sell the Galaxy S7 edge charging daughter board which can revive your port but fingers crossed it just needs a little more time to recoup.
If you do end up repairing it, keep in mind the phone will no longer be waterproof once breaking the adhesive seal ;(
Good luck!
Replace the daughter board that includes the USB port, primary microphone, and menu button touch sensors for an AT&T model Samsung Galaxy S7 Edge.の画像
製品
Galaxy S7 Edge Charging Daughter Board (AT&T)
$29.99
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Thank you so much for that information!! Yea drying it out and blowing into it with compressed air actually worked. The phone is now charging but at times it will think it is wet so it displays the check port notice but at least its charging!
さんによる
Glad to help Brian :)
さんによる
コメントを追加
Don”t blow on it, that just pushes the moisture and sand further in. Use a vacuum to suck t all out, works a lot better.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brian さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 8,818
