メインコンテンツにスキップ
初代Mac ProはIntel Xeonをベースにしたワークステーションコンピューターです。初代モデルには2006年から2008年のデバイスも含まれます。
Mac Pro wont just boot! + kernel panic
Hello,
Im trying too fix a mac pro 2008 3,1 3.0 8core. When its starts up it gives a kernel panic.
My first thoughts where that it had a bad hdd. I plugged it in another mac as a slave disk en got all sort of damage reports when using disk utility.
Internet recovery mode
Also when i tried internet recovery it wil not instal en fresh osx.
I got out the old hdd and plugged a new (old) one in. Which was completely erased and format journaled extended.
DVD
So ive tried to boot it with a dvd system disk os x lion (command +c) but its eventually gets a hickup and unfortunately shows a round sign with a stipe. Swap out the dvd drive with another one. same thing. new disk, same thing.
USB
next thing i've tried was to make it boot with a instal usb el captain. But when i startup with alt/option pressed it doesn't recognize the usb. and that sucks big time.
Ive cleaned the whole system which was pretty dusty and dirty.
I'm not a mac specialist and little bit out of options. I just cant get this sucker to run which i really want!!
Help/advise please!
In other comments i found a guy named Dan (@danj) and hope you can help me out.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Do you have the original system installation DVD for this machine?
さんによる
No i wish. I bought my mac at an E-Waste business down the street from my house i forgot to ask them for the cd's. shortly affter the business closed down.
on the topic of kernel panic try disabling sip
Follow these steps to disable SIP:
Restart your Mac.
Before OS X starts up, hold down Command-R and keep it held down until you see an Apple icon and a progress bar. Release. This boots you into Recovery.
From the Utilities menu, select Terminal.
At the prompt type exactly the following and then press Return: csrutil disable
Terminal should display a message that SIP was disabled.
From the  menu, select Restart.
also try disabling kexts.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
did you flash anything to you mp 3,1? are you able to get in recovery mode hold the alt.
System Software Overview:
System Version: macOS 10.13 (17A330h)
Kernel Version: Darwin 17.0.0
Boot Volume: macos high
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Nice insight on the possible flash!
さんによる
コメントを追加
回答を追加する
Vincent Limburg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 322
