メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
iPhone stuck in restoring
Tried to update phone's OS from 8.2.3(or something) to 10.2.3 only to have it stuck with the apple logo and the progress bar. As it reaches about 70 percent of the bar, it stops moving forward and eventually restarts.
I put it into DFU mode, tried updating with another computer and eventually it worked. Unfortunately, I'm now trying to revert back to the backup I had saved of the prior OS only to be stuck with the same problem with the progress bar and the apple logo as it reboots endlessly as the bar reaches about 70% and stops.
Am glad to provide any other helpful info.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Are you trying to restore the whole IOS system or just your files?
And you didn't by any chance happen to save your SSH blob? Unless you have, there is no way to downgrade your phone as Apple has stopped signing older versions of IOS.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I certainly wish I could restore the whole OS. I thought I could do so if it was from a backup. The files aren't as much of a matter, but still I'm annoyed that the phone gets stuck in a reboot loop.
Unfortunately not. Wasn't even aware of such things before updating. It turned out to be such a nuisance I felt like smashing the bloody phone, especially since it already had some problems and now they've been worsened by the update. Ah, well.
さんによる
I guess you know for next time!
(If the answer helped you, id appreciate if you could mark it as there chosen answer).
さんによる
コメントを追加
Not 100% sure this will work for you as it did me, but I heated up the phone a bit...about 80c to the back where it was very warm to touch and it completed with no errors. I eventually removed and reballed the NAND and issue went away all together.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Huh. Sounds like a rather unorthodox solution, but I might give it a try. I do wonder, though, how does one come up with these ideas for fixing a problem like this?
さんによる
コメントを追加
回答を追加する
Smeargle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 18
今までの合計 166
