メインコンテンツにスキップ
2015年3月のアップデートではAppleの11インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
141回答 すべてを表示
My battery runs out when is in sleep mode
I'm connected to the MagSafe with 100% of charge. I can disconnect the Mac and is all good. The problem is when I close the lid so when I go again to check the battery level, the Mac has a decent decrease of the battery charge level. When I turn off the Mac the level of the battery decrease in a slow way, but still doing it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Please download and run Coconut Battery so we can get a more in depth idea of the heath of your machine.
http://www.coconut-flavour.com
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hmm.... There are a number of things that could be wrong here. The battery could be defective, and thus your computer is acting up. Or perhaps you overcharged it at some point? Or did somehting else to strain the battery? It's a bit of a dificult procedure, but you could try to replace the battery with this guide. Or, you could take it in to your nearest Apple store. It will likely cost you, unless they can preform a simple (but otherwise unknown) fix on-site. If you're willing to try, you can make a Genius Bar reservation here. Finally, if you'd rather look for a third option, or just learn a bit about your battery, see Apple's page here.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Mayer's suggestion on checking the battery is good. Also, Apple stores will run their tests and do diagnosis for free...you don't have to have them do the repair.
さんによる
コメントを追加
回答を追加する
Axel Diaz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 715
