メインコンテンツにスキップ
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26回答 すべてを表示
Why does my chromebook keeps crashing?
i recently bought it and i noticed that it oftem randomly shuts down. though i can turn it back on, i find this occurance to be happening a lot that i find it annoying... around how much would it cost me to have it fixed?
thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
It depends on what is crashing your computer. Do you get any error messages or the Blue Screen of Death showing briefly? Does the computer slow down and finally shuts down? These kind of errors are generally indicate a problem with the operating system. If the computer shuts down very quickly, this may be a heat problem with your computer. Most hardware problems are consistent and shut down or not start up at all.
The cost to reinstall the operating system should not be too much and you can probably do it your self. Repairing hardware depends on the part that failed, the system board is a higher cost to repair than memory. A good tech should be able to sort out if the problem is hardware or software and give an estimate of repair cost.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Christine Aquino さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 4
今までの合計 1,918
