メインコンテンツにスキップ
AppleのiPad AirのWiFiモデルのバージョンはモデル番号A1474、スペースグレーと、シルバーがあり、カスタムA7プロセッサーが装備されており、容量は16、32、64、128GBがあります。
299回答 すべてを表示
Replace screen ipad air
I have two Ipad air 128GB both have Model A1474 but when I replaced screens they are different inside one had 3 wires and the other one it only has two wires on the screen that I was sent had no home button but does work but the problem is when I took the home button off the old one it fell apart and I don't know where to find the ribbon wire to replace or how to reassemble the old one why did I get two ipads but different inside? now I wonder if it will be touch screen when I put it back together
Update (07/15/2017)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
@dianelk65 possible to post pictures? Should have two ribbon connections on the side. The 3rd is your. Home button assembly, which is usually transferred from the damaged screen. However, I’ve seen screens come both ways, With and without a home button assembly. iPad home bottons can be tricky. Unlike iPhones they aren’t reinforced with plates with screws and a gasket with adhesive. If not removed properly and reinstalled without the adhesive and gasket, the button will eventually be pushed inside of the iPad. If you have any reservation about reassembling the button it’s best to buy a digitizer with home button assembly/flex.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
no where to plug in 3rd wire trying to post pics
さんによる
コメントを追加
I hope this helps. This is what I had when I replaced my screen. Hard to make out the cable connection from the photo. It was supposed to be kind if a zif style connector.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Diane Kersey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 207
