leak battery power becouse of weak signal
my phone got some water but it is still working only the problem is with the signal is so weak and it cause leak in battery power
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I wouldn't pin your battery problems to weak signal strength, you've probably done more damage to the board and battery than you think.
Although, yes, weaker signals use more battery than stronger ones due to packet lose, I think yourbattery is damaged.
このアンサーは役に立ちましたか?
if I changed the battery then what about the signal ? I feel the main problem is the signal
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 174
