メインコンテンツにスキップ
HPによるインクジェットプリンター、スキャナー、コピー機能が全て搭載されたデバイスです。モデル番号はCX042A。
20回答 すべてを表示
Why is my ink carridge not moving after a paper jam.
My printer was working fine but then had a paper jam. Removed jam but printer is not aknowledging this and the print cartridges wont move even manually. Can anyone help please as can't afford a new one? thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
How can I overcome the problem?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I'm not familiar with your printer, but I work with large format machines.
First off, It's important not to force the print carriage (the part that holds the print heads) as this could damage the belt that attaches to the motor or the motor itself.
As a first step, you can always turn both the printer and the computer all the way off and then back on. While the printer is off, unplug it and hold the power button for about 10 seconds. Not sure if it matters but I turn on the computer first, then the printer. That way I can make sure there is nothing in the print queue.
If that doesn't work, The manuals usually have troubleshooting for this kind of problem in the back section. There is usually something like a maintenance cartridge or other device that is keeping the motor engaged and will keep the print heads from being moved.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have done this but got no result
さんによる
Should I open the printer ?
さんによる
コメントを追加
回答を追加する
doddsarah さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 421
