My epson L220 printer : ink and paper red light blinking alternately
This problem occur when my friend refilled the ink.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Your printer waste ink counter overflow, you have to reset your printer waste ink counters.
Please try with this solution: https://resetkey.net/epson-l220-resetter...
このアンサーは役に立ちましたか?
epson printer l220 paper and ink blinking
i dont know how to do please help me
@maricel.cutie Step 1: Download WIC Reset Tool here: https://resetkey.net/download ,
Step 2: Connect printer and computer by USB Cable, computer connect to the Internet.
Step 3: Reset Epson L220 printer's waste ink counter by follow this guide: https://resetkey.net/epson-l220-resetter... - FREE to reset Waste ink counters to 90%
Watch this video:
Tested, tried and successful. You can reset your waste ink counter but you have to avoid waste ink pad overflow.
I found this video, helpful for me https://www.youtube.com/watch?v=rb3CIhXZ...
I found this post on ifixit: How to Hack Epson L200's Waste Ink Pad
Good luck!
このアンサーは役に立ちましたか?
Ink and paper lights blinking alternately means that your internal “waste ink pads” are full and need resetting/cleaning out.
Check your Epson Status Monitor (on PC) for any error messages - if it says “service required” or “…end of service life” then it’s the waste pads.
You’ll need to reset the internal counter using WIC Reset tool (a reset key can be had very cheaply).
Then you’ll need to either:
a) clean or replace the internal pads (usually just a case of removing one or two screws on the recent Epsons)
b) extend a piece of tubing out of the printer and directing all waste ink to an external container, such as a bottle or tub.
このアンサーは役に立ちましたか?
過去 24時間: 56
過去 7 日: 422
過去 30 日: 2,053
今までの合計 95,306
11 件のコメント
i need its solution....
Pravat dangol さんによる
my printer is alarm red light blink
Somu Biswas さんによる
please answer
Somu Biswas さんによる
Signal red light and paper jam
Somu Biswas さんによる
My printer is telling me that a printer's ink pad is at the end
Gift Rahman さんによる
6件以上のコメントを表示
