メインコンテンツにスキップ
How do you rebuild an electric bicycycle battery?
Electric bicycle batteries are mostly proprietary and are expensive--often the most expensive part of the e-bike, yet lithium ion cells from major manufactures are much less expensive. A bike battery should reasonably last 2-4 years depending on how they are charged and usage. You should not have to replace a $1,000 battery after two years, if there is a repair option out there. iFixit would seem to be an ideal forum for this with the increased interest in electric bikes for commuting, pleasure and adventure.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
最も参考になった回答
There are many websites showing you how to rebuild these batteries. You will need a cheap spot welder - check you tube for cheap device options. Buy the parts for the job from ebay etc.
If there is interest I will post some sites including warnings about the dangers of working with batteries
I found it simpler to adapt a more modern battery. Created adaper cable based on old battery parts and used hose clamps to mount battery. Battery from local vendor selling via ebay
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Joseph Dice さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,061
