メインコンテンツにスキップ
Nexus 6はGoogleとMotorolaによって開発されたAndroidスマートフォンで、6インチディスプレイを搭載して2014年に発売されました。
68回答 すべてを表示
Nexus 6 smd broken component
Hi, some time ago when i was dissasembling my Nexus 6 due to a camera replacement, i accidentally broke an smd component below the camera that is part of the screen well it only detached one pin ftom the two it has so i suited it in his place again and attached back the yellow transparent tape it has, i proceeded to reassemble the phone and all went good except when i low the brightness to certain point it starts to show Green lines and distortion but at a normal ir not so low brightness there Is no problem, Also i noticed an high amperage consumption and consequently a low battery duration i suppose it happens due to the broken component and want your advice if i should weld it again, it is very small and Is surrounded by many components as the same i broke, should i use heat gun? Or a soldering iron ? Tin welding ir liquid welding, or i just should heat the welding the component has and set it again un his place? There Is a photo of What im talking about (the photo Is from a broken screen i have but it shows the components)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I'm actually doing a similar repair right now and you need to use a soldering iron with a very thin tip. I just got this one: http://tinkersphere.com/electronics-tool...
Make sure the soldering iron doesn't touch any of the other components when you're reattaching it. It should be a very quick fix with the right tools.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bryan C さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 43
