メインコンテンツにスキップ
It was a six-wheeled tank with a front-mounted blue photon beam headlamp, and a keypad on top.
Elicits unending tone when GO is pressed
I used fresh batteries on a Big Trak, early 1980's model, which had not been used in more than two decades. After I program Big Trak, I press GO and all it does is elicit an unending, loud tone. I presume it is "stuck" somewhere. Who can repair this vehicle, if it is worthwhile or possible to repair?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Did you check to be sure the 9-volt is at 9 volts. Mine was at 8 and it was doing that exact thing. I am doing a once over before I put it up on e-bay, Mine is gray though. And I have the transport too.
さんによる
コメントを追加
1 件の回答
sounds like the motors are stalled.
I would work the drive wheels back and forth by hand and see if that frees it up. Also make sure ALL the batteries are fresh. These are real battery hogs.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gary Tameling さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 344
