メインコンテンツにスキップ
The LG K20 Plus Android smartphone was released by LG Electronics in March 2017 as part of the K Series. The LG K20 Plus includes model numbers LG K20 V, LG VS501, and LG TP260.
31回答 すべてを表示
How to fix my K20 plus cracked screen?
I dropped my new LG K20 Plus and the screen shattered.
How can I get it fixed?
Where to buy a screen?
What all parts do I need to buy?
Can I do the labor myself?
Do I need special tools?
If I can't fix it myself, where can I send it and how much will it cost?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
8 件のコメント
Can i fix it myself. And what all has to be replaced
さんによる
Is the digitizer glued on the display side or on the glass side of the screen, also what would be more effective for this repair... Dry ice or heat gun. i considered dry ice due to the fact that it is less likely to destroy the screen than heat is
さんによる
my friends cell phone screen is cracked but the cell phone still works!!!!!!!
さんによる
Cracked screen for LG K20 how much does it cost
さんによる
My Phone Broke because I was playing with a VR headset the holder for the phone shot out my phone. Model (LG K20 PLUS)
さんによる
3件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
Created this repair video just because I seen this thread. https://youtu.be/59ZarYHPPrE
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Dude you are awesome! This is the process right here folks! I watched to confirm.
さんによる
コメントを追加
I also have the same problem. This is my second LG K20 Plus phone and the screens on both broke with on a month of my purchasing them. The first time it slid off my bedside nightstand and shattered when it hit the floor (a drop of about 2.5 feet) and the second I simply had the phone in my pocket with nothing else in the pocket yet the pressure from my leg was enough to crack the screen.
My honest guess is the plastic body of the phone is too thin and so the phone body flexes cracking the screen. This is simply a poorly designed phone. Avoid it.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Replacement glass screen available here while the how to video can be found on youtube
https://m.ebay.com/itm/332318337221?_trk...
さんによる
Yeah so I call BS to the "you can find the teardown video on YouTube" I have scoured the internet and can't find a single tut/video on this phone..
さんによる
Ì agree. I found 1 on YouTube. But it was like he was working on a different phone. All of HIS components just came right out, they weren't affixed down like all of mine were. After he pulled off the last component he says, ok so there you go. Now just put it back together in the opposite order that you took it apart!! I was like, wtf??? What about my cracked screen?
さんによる
Yeah agreed. The 1 video on YouTube is for a different model, which is why the phone was different. I actually figured out that all those holes on the back where it looks like you are to pry up the back are misleading. The entire bezel is attached to the back casing so after you take out the battery and all of the screws the bezel comes off next, not the back casing only.. Hope that helps! If I ever have to do it again I will make a video and post to YouTube.
さんによる
Maybe you should read comment 2 on this page and you will see the link to the youtube video.
さんによる
1以上のコメントを表示
コメントを追加
just saw this video, i'm going to try it at home as well.
https://www.youtube.com/watch?v=szo_MCab...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Coincidentally his video went up a day after mine. Lol.
さんによる
コメントを追加
回答を追加する
Perryinjax さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 28,678
