メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
NuVision TM800A510Lは、2015年に発売されたAndroidタブレットです。スピーカー、インターネット機能、シンプルなユーザーインターフェースを備えており、主にメールや学習目的で使用されるタブレットです。
Ram upgrade and thermal paste upgrade?
nuvisionTM800W610L
I noticed that task manager and more say that there is one ram slot in use out of two. Is it possible to upgrade it with more ram? Also could someone upload a guide on how to take it apart so I can change my thermal paste wither better paste like grizzly cause I use this for gaming and I love it but it would benefit with more ram and better paste. Sadly no one has uploaded a teardown of it ever sooo please someone put up a guide/ video. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Anyone did it?
Can it be opened and RAM upgraded? or it's just an open slot for ram to be soldered.. (which means a future model with more ram on the way perhaps.. but useless to end users current)
さんによる
I don't believe there is any thermal paste to change on your tablet.
さんによる
コメントを追加
2件の回答
ベストアンサー
No, it's not user serviceable.
See this slick deals thread about it:
https://slickdeals.net/f/9512480-32gb-nu...
POST #474 12-13-2016 at 09:09 AM
"Unless you plan to do it with a soldering iron don't bother.. it's all 1 board everything is discrete, no user serviceable parts inside."
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It probably is but I think if the ram is upgraded you will need to modify the original OS or put a custom android OS on it to get the extra RAM to work but if you have root I sped up my old tablet a lot by overclocking the CPU a tiny bit (only a quarter of a gigahertz) and forcing the tablet to use more RAM
When I fix it I can make a tutorial for how to do that (the tablet is only broken because I purposely by aksedent corrupted the system partition to see what would happen)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
zZBuild ProneZz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 21
今までの合計 2,701
