メインコンテンツにスキップ
2015年1月発売。XPS 13ラップトップは”見た目はボーダレスなインフィニティディスプレイ”を搭載し、タッチスクリーンへアップグレード可能な、MacBook Airと対抗するべく開発されました。
20回答 すべてを表示
Can you buy this part anywhere?
Recently, when opening my xps 13, something snapped. After taking the back cover off, I realized that the part that holds the back left screw in snapped off so that the screw has nothing to screw into. This causes me to have to hold it together everytime I open and close the cover. I want to replace the part but I do not know what it is called or where to find it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Are you sure it still isn't under warranty? You can check here: http://www.dell.com/support/home/us/en/1...
さんによる
コメントを追加
2件の回答
ベストアンサー
Have you still got the part that snapped off? I assume it's some kind of pillar. You might be able to glue it back on with epoxy glue, and build up some extra epoxy around the fracture to give it the required strength. If you haven't got it or if that doesn't work, you could maybe re-form the pillar with thermoplastic - very sticky when hot and might just bind to the laptop shell sufficiently - then drill a hole in it to take the screw.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I think I'll try the thermoplastic. The only thing I'm not sure on is what size hole I should drill into it. I tried looking it up but I was only able to find that it was a t5 screw which I already knew and isn't that helpful.
さんによる
コメントを追加
What you are describing is the loss of a brass bushing that is set into the cover. The pillar is just plastic and can crack allowing the bushing to fall out. If the laptop is still in warranty then Dell will replace the cover unless it is found to be abuse damage. If it is out of warranty, use a plastic glue that is hard when cured and use sheet metal screws to hold together.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
John Sullivan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 145
